It is currently Sat Aug 16, 2025 5:26 am
PostPosted: Fri Oct 10, 2014 6:38 pm
Last Name: Sollod
Has anybody used Stew Mac's clear pickguard material? There are 2 ways to apply it, wet or dry. I would think that wet application might work better... Can you do the wet application on EM6000, since it's water based? Any tips for application? Looks like you could bugger it up if you're not careful...
www.swiftcreekguitars.com
PostPosted: Fri Oct 10, 2014 7:04 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Cut with sharp scissors and you can knock off any burr caused by the cutting with fins sandpaper 400 or finer. I apply with the wet method on lacquer so have no idea about on waterborn finishes.
Fred
Fred Tellier
PostPosted: Fri Oct 10, 2014 9:04 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
I've used it wet on EM6000 with no problem (heck I wet sand EM6000 to level it). If you put it on dry you'll have tapped air you can't get out that looks awful.
"I've been had again"
Tim Benware
Creedmoor, NC
PostPosted: Fri Oct 10, 2014 9:50 pm
Last Name: Killin
You wont have a problem with water and EM6000. You need to use a solvent (DNA) to reactivate it in order to get the burn in effect. I sprayed a coat of EM6000 on bird feeder that my daughter painted with some sort of craft paint. The bird feeder was outside in the elements for a couple of years with no damage from the water. I'm in no way saying to douse your guitar in water, but I don't think the little you need to apply a pick guard with the wet method will hurt it.
It does however react to rubber from a guitar stand. So be careful there.
PostPosted: Sat Oct 11, 2014 12:16 am
First name: Danny
Last Name: Vincent
I have found that if you cut the pick guard with a dedicated pair of new scissors it cuts clean and ready to install. Next step. Wash your hands. If you happen to touch the adhesive and you have any form of schmeg on your hands you will have to repeat step one. I put them on wet. I like to hold the pick guard upside down and give it a little spray of water with a drop of soap. I use a soft cloth to squeegee the water out.
These users thanked the author DannyV for the post: Flippo (Mon Oct 13, 2014 9:22 am)
PostPosted: Sat Oct 11, 2014 4:37 am
Water based here too.
Just don't touch the adhesive when the backing paper is off (fingerprints).
One drop of detergent in a 1/2 cup water, I spray on PG and soundboard then use a small flat eraser to remove air, like a squeegee.
As a hint, I find a craft circle cutter make a great job of the soundhole radius.
